Kensington SD4780P USB-C Dual 4K Docking Station
Quicklinx: G7FLWS00 Mfr#: K33620EU
The SD4780P USB-C & USB-A 10Gbps Dual 4K Hybrid Docking Station w/ 100W Power Delivery – DP++ & HDMI – Win/Mac/Chrome is the ultimate hybrid docking solution for Ultra High Definition Dual 4K @ 60Hz video. Features include the ability to select between HDMI 2.0 and DP++ 1.2, with four video ports in all (no need for cumbersome adapters); six USB ports; 100W of power delivery (perfect for the newer MacBook Pro); a 1m (3.28 feet) USB-C to USB-C cable with USB-A adapter (for USB-A devices that require power delivery, see our optional power splitter K38310); Thunderbolt 3 compatibility; optional Kensington DockWorks software, for the best connection, performance and security from your Kensington dock; and a three-year warranty. VESA compatible.
  • Dual 4K video output (HDMI 2.0 and DP++ 1.2 @ 60Hz)
    Delivers Ultra High Definition (4096 x 2160) images. Four video ports allow users the ability to select between HDMI 2.0 and DP++ 1.2 without the need for cumbersome adapters.
  • Universal hybrid docking
    The SD4780P connects to any USB-C or USB-A laptop, is Thunderbolt 3 compatible and supports Windows, Mac and Chrome operating systems.
  • 100W power delivery
    Ideal for devices that require higher power, such as the newer MacBook Pro.
  • Six USB ports (USB-C and USB-A)
    Two-layer hub delivers speeds of up to 10Gbps. Front: 1x USB-C 3.2 Gen2 up to 5V/3A and 1x USB-A 3.2 Gen2 up to 5V/2.4A; Back: 4x USB-A 3.2 Gen1 up to 5V/0.9A
  • Free Kensington DockWorks software
    Enables the best connection, performance and security from your Kensington dock.
  • Zero footprint mounting option
    Adjustable clamp easily attaches to a desktop edge, cubicle wall, monitor arm, or other surface for maximum mounting flexibility (K34050, sold separately).
Kensington SD4780P USB-C Dual 4K - docking station - USB-C / USB 3.0 - 2 x HDMI, 2 x DP++ - 1GbE
Docking station
Docking Interface
USB-C / USB 3.0
Video Interfaces
2 x HDMI, 2 x DP++
27 cm x 8.2 cm x 11.7 cm
1.27 kg
Europe
Gigabit Ethernet
Power adapter
3-year warranty
Docking station
27 cm
8.2 cm
11.7 cm
1.27 kg
Enclosure Colour
Europe
Video
Max Resolution Details
4096 x 2160 - 60 Hz
4 x USB-C 3.1 Gen 1 - 9 pin USB Type A , 2 x display / video - DisplayPort - 20 pin DisplayPort , 2 x display / video - HDMI - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm , 1 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x USB-C - 24 pin USB-C , 1 x USB-C 3.1 Gen 2 - 24 pin USB-C
1 x USB-C cable - external - 1 m , 1 x USB-C to USB 3.0 adapter - external
Security lock slot (cable lock sold separately), dual display support, 100W power delivery
Security Slot Type
Kensington security slot
DisplayPort 1.2
Power adapter
Limited warranty - 3 years
