Kensington SD4700P Universal USB-C Dock
Quicklinx: DDDDWS00 Mfr#: K38240EU
Supporting the advanced USB-C connections, and legacy computers with USB 3.0 ports, the SD4700P Universal USB-C and USB 3.0 Docking Station is the ideal docking solution for evolving computer environments. Engineered using stable technology, the SD4700P provides compatibility that just works. The SD4700P extends the life of your technology investments and is easy and painless to setup.
  • Versatile connectivity
    The Kensington SD4700P Dock offers a wide range of connection options with DisplayPort, HDMI, USB-C, and SuperSpeed USB 3.0 ports. This versatility ensures compatibility with a variety of devices and setups, making it a suitable solution for mixed-device environments.
  • Enhanced power delivery
    Equipped with a powerful 135 W power adapter, the dock provides ample power for charging laptops and mobile devices. The inclusion of a USB 3.0 fast charging port allows for quick charging of smartphones and tablets, ensuring your devices are always ready to go.
  • Comprehensive network support
    With support for Ethernet, Fast Ethernet, and Gigabit Ethernet, the Kensington SD4700P Dock ensures reliable, high-speed network connections. This feature is particularly beneficial for professionals who require stable and fast Internet access for video conferencing, large file transfers, and other bandwidth-intensive tasks.
Kensington SD4700P USB-C and USB 3.0 Dock - docking station - USB-C / USB 3.0 - HDMI, DP - 1GbE
Docking station
Docking Interface
USB-C / USB 3.0
Video Interfaces
HDMI, DP
20 cm x 9.12 cm x 3.05 cm
1.13 kg
Europe
Gigabit Ethernet
Power adapter AC 120/230 V / DC 20 V (50/60 Hz) 135 Watt Power Provided
Pricing Type
Brown Box
3-year warranty
Docking station
20 cm
9.12 cm
3.05 cm
1.13 kg
Enclosure Colour
Europe
1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 5 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB-C - 24 pin USB-C , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C cable - external - 1 m , 1 x USB-C to USB 3.0 adapter - external
Security lock slot (cable lock sold separately), VESA interface support, 1 USB 3.0 fast charging port, Zero Footprint Mounting
Security Slot Type
Kensington security slot
Plug and Play, FCC, RoHS, WEEE, REACH, RCM
Pricing Type
Brown Box
Power adapter
Power Provided
135 Watt
Microsoft Windows 7 / 10, Apple macOS 10.13 or later
Limited warranty - 3 years
