Supporting the advanced USB-C connections, and legacy computers with USB 3.0 ports, the SD4700P Universal USB-C and USB 3.0 Docking Station is the ideal docking solution for evolving computer environments. Engineered using stable technology, the SD4700P provides compatibility that just works. The SD4700P extends the life of your technology investments and is easy and painless to setup.
Versatile connectivity
The Kensington SD4700P Dock offers a wide range of connection options with DisplayPort, HDMI, USB-C, and SuperSpeed USB 3.0 ports. This versatility ensures compatibility with a variety of devices and setups, making it a suitable solution for mixed-device environments. -
Enhanced power delivery
Equipped with a powerful 135 W power adapter, the dock provides ample power for charging laptops and mobile devices. The inclusion of a USB 3.0 fast charging port allows for quick charging of smartphones and tablets, ensuring your devices are always ready to go. -
Comprehensive network support
With support for Ethernet, Fast Ethernet, and Gigabit Ethernet, the Kensington SD4700P Dock ensures reliable, high-speed network connections. This feature is particularly beneficial for professionals who require stable and fast Internet access for video conferencing, large file transfers, and other bandwidth-intensive tasks.
- Kensington SD4700P USB-C and USB 3.0 Dock - docking station - USB-C / USB 3.0 - HDMI, DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C / USB 3.0
- Video Interfaces
- HDMI, DP
- 20 cm x 9.12 cm x 3.05 cm
- 1.13 kg
- Black
- Localisation
- Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 120/230 V / DC 20 V (50/60 Hz) 135 Watt Power Provided
- Pricing Type
- Brown Box
- 3-year warranty
- Product Type
- Docking station
- 20 cm
- 9.12 cm
- 3.05 cm
- 1.13 kg
- Enclosure Colour
- Black
- Localisation
- Europe
- Data Link Protocol
- 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 5 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB-C - 24 pin USB-C , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Cables Included
- 1 x USB-C cable - external - 1 m , 1 x USB-C to USB 3.0 adapter - external
- Security lock slot (cable lock sold separately), VESA interface support, 1 USB 3.0 fast charging port, Zero Footprint Mounting
- Security Slot Type
- Kensington security slot
- Plug and Play, FCC, RoHS, WEEE, REACH, RCM
- Pricing Type
- Brown Box
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V / DC 20 V (50/60 Hz)
- Power Provided
- 135 Watt
- OS Required
- Microsoft Windows 7 / 10, Apple macOS 10.13 or later
- Limited warranty - 3 years
- 0 °C
- 40 °C
