Kensington Rocking Footrest
Quicklinx: G8R0WS00 Mfr#: K58303WW
£39.67 ex VAT
£47.60 inc VAT
With its comfortable, stable support, 136kg (300lbs) weight limit and 360° swivelling bar, the Rocking Foot Rest delivers ergonomics and promotes movement & stretching while sitting or standing. Strong, non-slip extruded rotating aluminium bar helps to improve circulation and relieve pressure for better health and all-day comfort.
  • Ergonomic design
    The rocking motion combined with an elevated surface promotes active sitting or standing, encouraging better posture and reducing fatigue over long periods of use.
  • Durable construction
    Crafted from high-quality aluminum with rubber-padded bases and non-slip rubber feet, this footrest is designed to withstand up to 136 kg, ensuring long-lasting durability and stability.
  • Versatile functionality
    Featuring a 360° swivel capability, this footrest offers flexibility, allowing users to find their most comfortable position effortlessly.
Kensington Rocking - footrest
Footrest
Material
Rubber, aluminium
2 years
Footrest
Material
Rubber, aluminium
360° swivel, elevated surface points, rubber-padded base, non-slip rubber feet, for sitting/standing, 136 kg weight capacity, rocking motion
Warranty
2 years
55.93 cm
21.81 cm
11.85 cm
1.16 kg
Shipping Width
65.45 cm
Shipping Depth
26.83 cm
Shipping Height
14.9 cm
Shipping Weight
1.79 kg
Brand: Kensington
