With the latest Windows OS, users have a huge array of options when it comes to getting the most out of their device, combining touchscreen and keyboard like no other. The Pro Fit Wired Windows Gesture Mouse features a multi-function gesture button that lets you perform up to six specific actions with your thumb that typically are accomplished with a touchscreen finger swipe. The mouse has a high-definition 1800 DPI sensor that optically tracks your hand movements for precision control. With two buttons, a gesture button, and a scroll wheel, the mobile design is highly comfortable, and with Plug & Play installation you can get up and running quickly.
- Kensington Pro Fit - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- 5.8 cm x 9.9 cm x 3.8 cm
- Movement Detection Technology
- Optical
- Buttons Qty
- 4
- Movement Resolution
- 1800 dpi
- Scrolling wheel, gesture function
- OS Required
- Windows 8 / 8.1 / 10
- 3-year warranty
- Mouse
- 5.8 cm
- 9.9 cm
- 3.8 cm
- Black
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 4
- 1800 dpi
- 1 x USB - 4 pin USB Type A
- Plug and Play
- OS Required
- Limited warranty - 3 years
