Kensington Pro Fit Wired Mid-Size Mouse
Quicklinx: CRJSWS00 Mfr#: K72355EU
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
£24.55 ex VAT
£29.46 inc VAT
The Pro Fit range delivers performance and comfort that business users require, day after day, without any fuss. Designed specifically for the business professional the Pro Fit range is the perfect step up from entry level input devices delivering perfomance that can be relied upon.
  • Ergonomic design
    Designed specifically for right-handed users, this mouse offers an ergonomic shape that fits comfortably in the hand, reducing strain during long work sessions.
  • High precision
    With a movement resolution of 1000 DPI, this optical mouse provides precise control and navigation, enhancing productivity and efficiency in any task.
  • Durable and reliable
    The spill-proof design ensures that accidental spills won't disrupt your work, making it a reliable choice for busy environments.
Kensington Pro Fit Mid-Size - mouse - USB - black
Mouse
Wired - USB
Orientation
Right-handed
6.7 cm x 10 cm x 3.8 cm
100 g
Europe
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
1000 dpi
Spill-proof
Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
Right-handed
6.7 cm
10 cm
3.8 cm
100 g
Europe
Input Device
Wired
USB
Optical
Buttons Qty
5
Movement Resolution
1000 dpi
Spill-proof
1 x USB - 4 pin USB Type A
Plug and Play
Limited warranty - 3 years
Type: Mouse
Colour: Black
Compatibility: PC
Brand: Kensington
