Kensington Pro Fit Retractable Mobile Mouse
Quicklinx: CRJRWS00 Mfr#: K72339EU
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac, PC
£19.58 ex VAT
£23.49 inc VAT
The Pro Fit range delivers performance and comfort that business users require, day after day, without any fuss. Designed specifically for the business professional the Pro Fit range is the perfect step up from entry level input devices delivering perfomance that can be relied upon.
  • Effortless compatibility
    Designed to seamlessly integrate with both Mac and PC systems, the Kensington Pro Fit Retractable Mobile mouse offers a versatile solution for any workspace. Its Plug-and-Play feature, along with Windows 7 compatibility, ensures a hassle-free setup, allowing users to get started immediately without the need for additional software or drivers.
  • Precision control
    Equipped with optical movement detection technology and a 1000 DPI resolution, this mouse delivers precise cursor control for a wide range of tasks. Whether it's navigating through documents or designing in a digital workspace, users can expect smooth and accurate tracking.
  • Convenient design
    The retractable cable feature of the Kensington Pro Fit Retractable Mobile mouse ensures a clutter-free workspace. This design allows for easy adjustment of cable length, making it perfect for on-the-go use or when desk space is limited. The integrated USB cable facilitates a reliable wired connection for uninterrupted use.
Kensington Pro Fit Retractable Mobile - mouse - USB - black
Mouse
Wired - USB
5.4 cm x 9 cm x 3.5 cm
130 g
Europe
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Retractable cable
1 x USB cable - integrated
Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
Mouse
5.4 cm
9 cm
3.5 cm
130 g
Europe
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Retractable cable
1 x USB - 4 pin USB Type A
Plug and Play, FCC
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Kensington
