Performance, comfort and reliability are critical in any office environment, the Pro Fit Wired Mid-Size Mouse delivers this every working day. The full-size right-handed ergonomic design makes it ideal for smaller hands. Conveniently located browser navigation buttons and scroll wheel help users complete tasks quicker. Plug and Play wired USB avoids setup pains.
Ergonomic design
Designed specifically for right-handed users, this mouse offers an ergonomic shape that fits comfortably in the hand, reducing strain during extended use. -
High precision tracking
With a movement resolution of 1600 DPI, the optical sensor provides accurate and smooth cursor control, enhancing productivity and gaming experiences. -
Convenient wireless connectivity
Eliminate the clutter of cables with wireless connectivity. The 2.4 GHz interface ensures a reliable connection with a USB wireless receiver for easy Plug-and-Play setup. -
Extended battery life
Powered by two AAA batteries, this mouse is designed for use, ensuring you stay productive without frequent interruptions for battery changes. -
Versatile compatibility
Fully compatible with PC systems, this mouse is ready to plug and play, making it a suitable choice for a wide range of computing tasks.
- Kensington Pro Fit Mid-Size - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right-handed
- 6.6 cm x 10.2 cm x 3.5 cm
- 120 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 6
- Movement Resolution
- 1600 dpi
- Scrolling wheel
- Battery
- 2 x AAA type
- 2-year warranty
- Mouse
- Wireless Receiver
- Orientation
- Right-handed
- 6.6 cm
- 10.2 cm
- 3.5 cm
- 120 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- Buttons Qty
- 6
- 1600 dpi
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- Plug and Play
- AAA type
- Installed Qty
- 2
- Run Time (Up To)
- 1 year
- Limited warranty - 2 years
