Kensington Pro Fit Mid-Size Wireless Mouse
Quicklinx: CRJTWS00 Mfr#: K72405EU
Recommended Use: Office
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
£24.09 ex VAT
£28.90 inc VAT
Performance, comfort and reliability are critical in any office environment, the Pro Fit Wired Mid-Size Mouse delivers this every working day. The full-size right-handed ergonomic design makes it ideal for smaller hands. Conveniently located browser navigation buttons and scroll wheel help users complete tasks quicker. Plug and Play wired USB avoids setup pains.
  • Ergonomic design
    Designed specifically for right-handed users, this mouse offers an ergonomic shape that fits comfortably in the hand, reducing strain during extended use.
  • High precision tracking
    With a movement resolution of 1600 DPI, the optical sensor provides accurate and smooth cursor control, enhancing productivity and gaming experiences.
  • Convenient wireless connectivity
    Eliminate the clutter of cables with wireless connectivity. The 2.4 GHz interface ensures a reliable connection with a USB wireless receiver for easy Plug-and-Play setup.
  • Extended battery life
    Powered by two AAA batteries, this mouse is designed for use, ensuring you stay productive without frequent interruptions for battery changes.
  • Versatile compatibility
    Fully compatible with PC systems, this mouse is ready to plug and play, making it a suitable choice for a wide range of computing tasks.
Kensington Pro Fit Mid-Size - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right-handed
6.6 cm x 10.2 cm x 3.5 cm
120 g
Wireless Receiver
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
1600 dpi
Scrolling wheel
2 x AAA type
Mouse
Wireless Receiver
Orientation
Right-handed
6.6 cm
10.2 cm
3.5 cm
120 g
Input Device
Wireless
2.4 GHz
Optical
Buttons Qty
6
Movement Resolution
1600 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play
AAA type
Installed Qty
2
Run Time (Up To)
1 year
Type: Mouse
Colour: Black
Compatibility: PC
Brand: Kensington
