Kensington Pro Fit Mid-Size Wireless Mouse - Sapphire Blue
Quicklinx: CRJVWS00 Mfr#: K72421WW
Recommended Use: Office
Type: Mouse
Wired / Wireless: Wireless
Colour: Sapphire blue
Compatibility: PC
10 In Stock
£24.80 ex VAT
£29.76 inc VAT
Performance, comfort and reliability are critical in any office environment, the Pro Fit Wired Mid-Size Mouse delivers this every working day. The full-size right-handed ergonomic design makes it ideal for smaller hands. Conveniently located browser navigation buttons and scroll wheel help users complete tasks quicker. Plug and Play wired USB avoids setup pains.
  • Effortless connectivity
    With its Nano wireless receiver, the Kensington Pro Fit Mid-Size mouse offers seamless connectivity via a 2.4 GHz interface, ensuring a reliable link between the mouse and your PC without the hassle of wires.
  • Precision tracking
    Equipped with an optical movement detection technology, this mouse delivers a high movement resolution of 1750 DPI, allowing for precise control and tracking on a variety of surfaces.
  • Designed for comfort
    The right-handed orientation of the Kensington Pro Fit Mid-Size mouse is engineered for comfort, making it ideal for extended use without causing hand fatigue.
Kensington Pro Fit Mid-Size - mouse - 2.4 GHz - sapphire blue
Mouse
Wireless - 2.4 GHz
Sapphire blue
Orientation
Right-handed
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Movement Resolution
1750 dpi
Scrolling wheel, Nano wireless receiver
2 x AAA type
Mouse
Wireless Receiver
Orientation
Right-handed
Sapphire blue
Input Device
Wireless
2.4 GHz
Optical
Movement Resolution
1750 dpi
1 x USB - 4 pin USB Type A
Plug and Play
AAA type
Installed Qty
2
Run Time (Up To)
1 year
Type: Mouse
Compatibility: PC
Brand: Kensington
