Kensington Pro Fit Mid-Size Wireless Mouse - Graphite Grey
Quicklinx: CRJXWS00 Mfr#: K72423WW
Recommended Use: Office
Type: Mouse
Wired / Wireless: Wireless
Colour: Graphite grey
Compatibility: PC
36 In Stock
£24.09 ex VAT
£28.90 inc VAT
Performance, comfort and reliability are critical in any office environment, the Pro Fit Wired Mid-Size Mouse delivers this every working day. The full-size right-handed ergonomic design makes it ideal for smaller hands. Conveniently located browser navigation buttons and scroll wheel help users complete tasks quicker. Plug and Play wired USB avoids setup pains.
  • Ergonomic design
    Designed specifically for right-handed users, this mouse offers an ergonomic shape that fits comfortably in the hand, reducing fatigue during long work sessions.
  • Seamless connectivity
    With its 2.4 GHz wireless technology, the Kensington Pro Fit Mid-Size mouse ensures a reliable connection without the hassle of wires, providing a clean and uncluttered workspace.
  • Precision tracking
    Featuring an optical movement detection technology with a 1600 DPI resolution, this mouse delivers smooth and precise tracking on a variety of surfaces.
  • Customizable performance
    Real-time sensitivity switching between 800, 1200, and 1600 DPI allows users to adjust the mouse's responsiveness based on the task at hand, enhancing productivity and user experience.
  • Convenient features
    Equipped with a battery indicator, on/off power switch, and a nano wireless receiver that can be stored in the mouse, this device is designed for ease of use and portability.
Kensington Pro Fit Mid-Size - mouse - 2.4 GHz - graphite grey
Mouse
Wireless - 2.4 GHz
Graphite grey
Orientation
Right-handed
6.6 cm x 10.2 cm x 3.5 cm
110 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
Realtime sensitivity switching 800/1200/1600 dpi
Scrolling wheel, battery indicator, on/off power switch, Nano wireless receiver, wireless receiver slot, navigation wheel, DPI switch
AAA type
Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Microsoft Windows XP / Vista / 7 / 8 / 10, Apple MacOS X 10.11, Apple MacOS X 10.10 or later, Apple macOS Sierra 10.12, Google Chrome OS 44 or later, Apple macOS 10.13 or later
Mouse
Wireless Receiver
Orientation
Right-handed
6.6 cm
10.2 cm
3.5 cm
110 g
Graphite grey
Input Device
Wireless
2.4 GHz
Optical
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
1 x USB - 4 pin USB Type A
Plug and Play
AAA type
Run Time (Up To)
12 months
Shipping Width
13.5 cm
Shipping Depth
3.81 cm
Shipping Height
20.3 cm
Shipping Weight
181 g
Type: Mouse
Compatibility: PC
Brand: Kensington
