Kensington Pro Fit Low-Profile Desktop Set - Wireless
Quicklinx: D90GWS00 Mfr#: K75230uk
Recommended Use: Leisure
Type: Keyboard
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC, Mac
43 In Stock
£29.89 ex VAT
£35.86 inc VAT
About This Product
The Kensington Pro Fit Low-Profile Wireless Desktop Set is a reliable solution for the professional workstation. Providing a full-size, spill-proof keyboard with multimedia keys, a comfortable ambidextrous mouse and AES encryption, the Pro Fit Low-Profile Wireless Desktop Set supports a clutter-free and secure workstation.
  • Low-profile, full-size keyboard provides multimedia keys for enhanced productivity and quick access to frequently used applications and files
  • Ambidextrous mouse is designed to provide all-day comfort for the right or left hand and provides an optical sensor with 1200 DPI for precise control
  • 2.4GHz USB receiver provides a reliable wireless connection up to 10 metres for the keyboard and mouse
  • Professional design offers smooth, low-profile keys to make typing more efficient and comfortable
  • Secure wireless connection protects sensitive data from potential hackers using AES 128-bit encryption technology
  • Spill-proof keyboard resistant to coffee, water and other liquids
  • Plug & Play allows you to plug the receiver into your computer’s USB port and immediately start using your keyboard and mouse
Transfer from a laptop or notebook keyboard to a more comfortable set-up offering a number pad, directional keys andmultimedia keys you can use to access frequently used applications like your browser and email, as well as My Computer or This PC (Win10).
Ambidextrous Mouse
Comfort and precision to enhance your productivity. Ergonomically designed to provide all-day comfort for your right or left hand and provides an optical sensor with 1200 DPI for precise control.
2.4GHz USB receiver
Provides a reliable wireless connection up to 10 metres for the keyboard and mouse.
Professional Design
Offers smooth, low-profile keys to make typing more efficient and comfortable.
Secure Wireless Technology
Adopted by the U.S. government as the encryption standard, the AES 128-bit encryption protects your sensitive data from potential hackers.
Spill-Proof Keyboard
A sealed membrane design lets liquids run through without damaging your keyboard’s electronics. Resistant to everything from coffee to water, this keyboard can be easily cleaned after a spill and continue to be used.
Plug & Play
Simply plug the receiver into your computer’s USB port to experience the benefits of a secure and clutter-free desktop.
  • Seamless compatibility
    Designed to work effortlessly with both Mac and PC, the Kensington Pro Fit Low-Profile Desktop Set ensures smooth integration into any workspace. Its dual compatibility eliminates the need for multiple input devices, streamlining your desktop setup.
  • Wireless convenience
    Experience the freedom of wireless connectivity with the Kensington Pro Fit Desktop Set. The 2.4 GHz interface provides a reliable connection without the clutter of cables, paired with a USB wireless receiver for easy Plug-and-Play setup.
  • Enhanced productivity
    Featuring dedicated browser, email, and multimedia keys, this keyboard and mouse set is tailored for efficiency. The inclusion of a numeric keypad further enhances data entry speed, making it a suitable choice for professionals.
  • Precision control
    The optical mouse offers precise movement tracking with a 1000 DPI resolution, suitable for both right- and left-handed users. Its three-button design ensures easy navigation and functionality, complementing the keyboard's productivity features.
Kensington Pro Fit Low-Profile Desktop Set - keyboard and mouse set - UK Input Device
Keyboard and mouse set
2.4 GHz
Wireless Receiver
Wireless
Localization and Layout
Hot Keys Function
Multimedia, e-mail, browser
Numeric Keypad
Pointing Device
Mouse - wireless - optical - right and left-handed
Buttons Qty
3
3-year warranty
2.4 GHz
Wireless Receiver
Wireless
Hot Keys Function
Region
United Kingdom
Numeric keypad
Pointing Device
Mouse - wireless
Buttons Qty
3
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Orientation
Right and left-handed
Apple MacOS, Windows 8.1 / 10
Limited warranty - 3 years
Type: Keyboard
Colour: Black
Compatibility: PC
Compatibility: Mac
Brand: Kensington
