The features that matter most in your office are comfort and reliability. And the Kensington Pro Fit 2.4 GHz Wireless Full-Size Mouse delivers with plenty of both. The full-sized right-handed design feels great in the hand while the 2.4GHz wireless technology is ideal for crowded office environments.
- Kensington Pro Fit Full-Size - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right-handed
- 7.8 cm x 12 cm x 4 cm
- 210 g
- Localisation
- Europe
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 6
- Movement Resolution
- 1200 dpi
- Scrolling wheel, soft rubber grip
- Battery
- 2 x AA type
- OS Required
- Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista / XP
- Mouse
- Wireless Receiver
- Orientation
- Right-handed
- 7.8 cm
- 12 cm
- 4 cm
- 210 g
- Black
- Localisation
- Europe
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- Buttons Qty
- 6
- 1200 dpi
- 1 x USB - 4 pin USB Type A
- Plug and Play
- AA type
- Installed Qty
- 2
- OS Required
