Protect the sensitive information on your screen with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
The limited viewing angle narrows the field of vision on the screen to +/- 30 degrees, helping you keep the information on your screen private and reducing the chances of a visual data breach, which is important both in the office or in a public setting.
Blue light reduction technology filters out the harmful rays by up to 30%, easing eye strain and reducing the chances of blue light interrupting your natural sleep patterns.
The privacy screen can be mounted either with the included frameless tab holders that attach to the edges of your monitor, letting you quickly and easily insert or remove the privacy screen, or you can mount it with double-sided tape that adheres directly to the screen for a cleaner look.
Reduced glare from any outside light source with the Anti-Reflective Coating, that can interfere with your viewing clarity.
Either side of the privacy screen can be used to different effect. One side has a matte finish to maximize glare reduction, is smooth to the touch and reduces traces of fingerprints. The other side is glossy and provides a clearer view of the monitor screen.
Suitable for any Standard 24" Widescreen 16:10 Monitor screen.
Enhanced privacy
The 2-way privacy protection ensures that your screen content is shielded from prying eyes, offering peace of mind in public spaces or open office environments. -
Durable design
Equipped with a 3H hard-coating, this display privacy filter is designed to resist scratches and damage, maintaining the integrity of your screen. -
Easy to use
Thanks to its removable feature, the privacy filter can be easily attached or detached from your monitor, allowing for flexibility in its use and maintenance.
- Kensington display privacy filter - 24"
- Product Type
- Display privacy filter - 2-way
- Installation Type
- Removable
- Display Screen Size Compatibility
- 24"
- 51.9 cm x 0.039 cm x 32.5 cm
- 80 g
- Product Type
- 24"
- 51.9 cm - 0.039 cm - 32.5 cm
- 80 g
- Shipping Dimensions (WxDxH) / Weight
- 35 cm x 0.5 cm x 59.5 cm / 380 g
Display Filter
- Privacy Protection
- 2-way
- Installation Type
- Removable
- Aspect Ratio
- 16:10
- 3H hard-coating
