Kensington Privacy Filter for 26" Monitors 16:10 - 2-Way Removable
Quicklinx: G8V2WS00 Mfr#: 626490
£73.93 ex VAT
£88.71 inc VAT
Protect the sensitive information on your monitor with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
  • Enhanced privacy
    The 2-way privacy protection ensures that your screen remains visible only to you, safeguarding sensitive information from prying eyes.
  • Durable design
    Equipped with a 3H hard-coating, this display privacy filter resists scratches and damage, maintaining the integrity of your screen.
  • Easy to use
    Thanks to its removable feature, you can easily attach and detach the filter from your display, offering flexibility and convenience for different situations.
Kensington display privacy filter - 26"
Display privacy filter - 2-way
Installation Type
Removable
Display Screen Size Compatibility
26"
55.01 cm x 0.039 cm x 34.38 cm
90 g
26"
55.01 cm - 0.039 cm - 34.38 cm
90 g
44 cm x 0.5 cm x 72.5 cm / 510 g
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Aspect Ratio
16:10
3H hard-coating
Brand: Kensington
