Kensington Privacy Filter for 22" Monitors 16:10 - 2-Way Removable
Quicklinx: G8TGWS00 Mfr#: 626483
34 In Stock
£40.15 ex VAT
£48.18 inc VAT
Protect the sensitive information on your monitor with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
  • Enhanced privacy
    The Kensington display privacy filter offers privacy protection, ensuring that your sensitive information remains confidential during use. Ideal for busy areas or open office environments.
  • Versatile compatibility
    Designed to perfectly fit a 22" screen with a 16:10 aspect ratio, this privacy filter provides a seamless fit for optimal viewing and protection.
  • Durable design
    Featuring a durable coating, the Kensington privacy filter is built to resist scratches and damage, maintaining the clarity and integrity of your screen.
  • Easy to use
    With its removable feature, the privacy filter can be easily attached or detached from your monitor, allowing for flexibility in its use and maintenance.
Kensington display privacy filter - 22"
Display privacy filter - 2-way
Installation Type
Removable
Display Screen Size Compatibility
22"
47.4 cm x 0.039 cm x 29.7 cm
70 g
22"
47.4 cm - 0.039 cm - 29.7 cm
70 g
32.5 cm x 0.5 cm x 53.5 cm / 310 g
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Aspect Ratio
16:10
3H hard-coating
Brand: Kensington
