Protect the sensitive information on your monitor with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
Enhanced privacy
With its 2-way privacy protection, this display filter ensures that your information stays confidential, making it ideal for high-traffic areas or open office environments. -
Versatile compatibility
Designed to fit 20" screens, this privacy filter offers a seamless fit for a broad range of monitors, ensuring that your screen is protected without sacrificing display quality. -
Durable design
Featuring a 3H hard-coating, this display privacy filter is built to resist scratches and damage, keeping your screen pristine and clear under any circumstances. -
Easy to use
The removable feature of this privacy filter allows for quick and easy attachment or removal, making it convenient for users who need to share their screen or safeguard their information on-the-go.
- Kensington display privacy filter - 20"
- Product Type
- Display privacy filter - 2-way
- Installation Type
- Removable
- Display Screen Size Compatibility
- 20"
- 44.3 cm x 0.039 cm x 25 cm
- 50 g
- Product Type
- 20"
- 44.3 cm - 0.039 cm - 25 cm
- 50 g
- Shipping Dimensions (WxDxH) / Weight
- 32.5 cm x 0.5 cm x 53.5 cm / 290 g
Display Filter
- Privacy Protection
- 2-way
- Installation Type
- Removable
- Aspect Ratio
- 16:9
- 3H hard-coating
