Kensington Privacy Filter for 19" Monitors 5:4 - 2-Way Removable
Quicklinx: G8V5WS00 Mfr#: 626476
£42.06 ex VAT
£50.47 inc VAT
Protect the sensitive information on your monitor with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
  • Enhanced privacy
    With its bidirectional privacy protection, this display privacy filter ensures that your information remains confidential, ideal for high-traffic areas or open office environments.
  • Durable design
    Featuring a 3H hard-coating, this filter is designed to resist scratches and damage, keeping your screen pristine and clear.
  • Easy to use
    Thanks to its removable feature, you can easily attach and remove the privacy filter from your display, offering flexibility and convenience for any user.
Kensington display privacy filter - 19"
Display privacy filter - 2-way
Installation Type
Removable
Display Screen Size Compatibility
19"
37.7 cm x 0.039 cm x 30.2 cm
50 g
19"
37.7 cm - 0.039 cm - 30.2 cm
50 g
35 cm x 0.5 cm x 59.5 cm / 290 g
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Aspect Ratio
5:4
3H hard-coating
Brand: Kensington
