Kensington Privacy Filter for 19" Monitors 16:10 - 2-Way Removable
Quicklinx: G8V6WS00 Mfr#: 626477
£42.67 ex VAT
£51.20 inc VAT
Protect the sensitive information on your monitor with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
  • Enhanced privacy
    The 2-way privacy protection ensures that your sensitive information remains confidential, making it an ideal solution for high-traffic areas and open office environments.
  • Versatile compatibility
    Designed to perfectly fit a 19" display or 48.3 cm in metric measurements, this display privacy filter offers a seamless fit for a wide range of monitors, enhancing visual security without sacrificing screen clarity.
  • Durable design
    Equipped with a 3H hard-coating, this privacy filter not only protects your screen from prying eyes but also defends against scratches and damage, ensuring your monitor remains in pristine condition.
Kensington display privacy filter - 19"
Display privacy filter - 2-way
Installation Type
Removable
Display Screen Size Compatibility
19"
40.8 cm x 0.039 cm x 25.5 cm
50 g
19"
40.8 cm - 0.039 cm - 25.5 cm
50 g
32.5 cm x 0.5 cm x 53.5 cm / 290 g
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Aspect Ratio
16:10
3H hard-coating
Brand: Kensington
