Kensington Privacy Filter 2 Way Removable 34" Samsung C34H890 Curved Monitor
Quicklinx: G8VDWS00 Mfr#: 627208
Hurry, only 3 left in stock!
£170.65 ex VAT
£204.78 inc VAT
Protect the sensitive information on your tablet screen with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
  • Blue light reduction
    Filters out the harmful rays by up to 30%, easing eye strain and reducing the chances of blue light interrupting your natural sleep patterns.
  • Installation options
    The privacy screen can be mounted either with the included frameless tab holders that attach to the edges of your monitor, letting you quickly and easily insert or remove the privacy screen, or you can mount it with double-sided tape that adheres directly to the screen for a cleaner look.
  • Anti-reflective coating
    Reduces glare from any outside light sources that can interfere with your viewing clarity.
  • Reversible viewing
    Either side of the privacy screen can be used to different effect. One side has a matte finish to maximize glare reduction, is smooth to the touch and reduces traces of fingerprints. The other side is glossy and provides a clearer view of the monitor screen.
Kensington display privacy filter - 34" wide
Display privacy filter - 2-way
Installation Type
Removable
Display Screen Size Compatibility
34" wide
Samsung C34H890WJA, C34H890WJE, C34H890WJL, C34H890WJN, C34H890WJU
34" wide
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Aspect Ratio
21:9
Brand: Kensington
