Kensington Presenter Expert Red Laser
Quicklinx: 8ZMYWS00 Mfr#: K72425EU
£35.33 ex VAT
£42.39 inc VAT
Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter with Red Laser Pointer & Cursor Control. Sometimes pointing just isnt enough. With a simple flick of a switch, you toggle between presentation and cursor control modes. The wireless 2.4GHz receiver stores conveniently inside the remote, and since its uniquely paired, you dont have to worry about device interference.
  • Effortless control
    The Kensington Presenter Expert is designed with backlit buttons and a built-in laser pointer, ensuring seamless presentations even in fully lit or dark environments.
  • Extended reach
    With a maximum operating distance of 50 m, this presentation remote control offers the freedom to move around large rooms or auditoriums, engaging with the audience without being tethered to a device.
  • Reliable performance
    Equipped with a low battery alert and an easy power on/off feature, the Kensington Presenter Expert ensures your presentations go smoothly without interruptions for battery changes.
Kensington Presenter Expert Red Laser with Cursor Control presentation remote control - black
Presentation remote control
Enclosure Colour
Europe
Radio
Max Operating Distance
50 m
Pointing device battery
Enclosure Colour
Europe
Radio
50 m
Low battery alert, built-in laser pointer, back-lit buttons, power on/off
Operating System
Apple Mac OS, MS Windows 7, Windows 8
Carrying pouch
