Kensington Premium Cool-Gel Seat Cushion
Quicklinx: G8QSWS00 Mfr#: K55807WW
£36.53 ex VAT
£43.83 inc VAT
The Kensington Premium Cool-Gel Seat Cushion provides ultimate ergonomic comfort and support for sitting in the office, home or car. Constructed with patent pending materials, and certified for durability, the Premium Cool-Gel Seat Cushion features a durable and supportive ergonomic design that maximises comfort, promotes healthy posture, and minimises contact between the tailbone and seat cushion.
  • Cooling fabric with cool-gel core
    Provides maximum comfort during extended periods of sitting using a soft cooling fabric, and internal cooling gel, to deliver a certified decrease in body temperature. Sitting has never felt so cool.
  • Ergonomic design
    Promotes healthy posture, improves circulation, and relieves spinal pressure to help reduce the discomfort, fatigue and stiffness that can result from extended periods of sitting.
  • Zero tailbone pressure
    Alleviates the pressure on your spine and supports sciatica relief by minimizing the contact between your tailbone and the seat cushion. Provides relief and comfort whether you're sitting in the office, at home or in a car.
  • Premium honeycomb memory foam
    Provides durable and professional patent pending structural support that will maintain its shape use after use in any environment.
  • Anti-slip backing
    Prevents sliding using a high-quality silicone friction grip so you can sit with confidence.
Kensington Premium Cool Gel Seat Cushion - seat cushion - black
Seat cushion
Material
Cool-Gel, memory foam
2 years
Seat cushion
Material
Warranty
2 years
46.5 cm
36 cm
7.5 cm
1.34 kg
Brand: Kensington
