Kensington PowerBolt 3.4 Amp Dual USB Fast Charger & Lightning Cable
Quicklinx: CRKTWS00 Mfr#: K39794WW
Chances are, if you have one Apple device, you've got at least one other Apple product thats also going to need charging. The Kensington PowerBolt 3.4 Dual Port Fast Charge has a built-in Lightning charging cable and 2.4 AMPs of power for your iPad. Plus, theres also a USB charging port with 1.0 AMP for your iPhone 5, 5s or 5c, or other Apple device. Simply use the charging cable that came with your device and youre ready for a fast, safe charge.
The PowerBolt 3.4 is ideal if you need to charge your iPad that uses a lightning cable, including iPad Air/4th gen/mini/mini with Retina and iPhone 5/5s/5c simultaneously in the car. With the Kensington PowerBolt 3.4 Fast Charge youll arrive at your destination with a full charge, so you can get back to surfing the web, typing emails, checking social media, talking on the phone and oh yeah, maybe even working. The Kensington PowerBolt 3.4 Fast Charge features a compact, low-profile design that blends in with any vehicle interior and wont interfere with your cars controls.
  • Efficient charging
    With a maximum electric current of 2.4 A, this car charger ensures your devices are charged efficiently, minimizing downtime and keeping you connected on the go.
  • Dual port convenience
    Featuring two output connectors, a 4-pin USB Type-A and an Apple Lightning, the Kensington PowerBolt 3.4 Dual Port Fast Charge Car Charger offers the flexibility to charge multiple devices simultaneously.
  • Easy connectivity
    The integrated Lightning cable and additional USB port make it easy to connect and charge a wide range of devices, ensuring you're always prepared, no matter what tech you carry.
  • Designed for mobility
    Specifically designed for use in vehicles, this charger plugs into any automobile cigarette lighter, making it an ideal solution for charging your devices on the road.
  • Illuminated design
    Equipped with blue LEDs, the charger provides subtle illumination, making it easier to locate and use in low-light conditions, enhancing both functionality and aesthetic appeal.
Kensington PowerBolt 3.4 Dual Port Fast Charge Car Charger car power adapter - USB, Lightning
Car power adapter
Output Connector Type
Total 2: USB, Lightning
Max Electric Current
2.4 A
Cables
Lightning cable
Car power adapter
Tablet, mobile phone
Enclosure Colour
Input Connectors
Automobile cigarette lighter
Input Connectors Qty
1
Output connectors
Total 2: 4 pin USB Type A, Apple Lightning
2.4 A
Blue LEDs
Lightning cable
