Designed in partnership with Microsoft, the Portable Keyed Cable Lock secures Surface Pro & Surface Go devices with the same quality and strength that has made Kensington The Professionals' Choice for more than 25 years. Developed using strict specifications, patented technologies, and rigorous testing against tough environmental conditions, the Keyed Cable Lock for Surface Pro & Surface Go provides next generation security for Microsoft Surface Pro & Surface Go devices.
Non-invasive locking technology
Attaching without the need for any tools or glue-on pieces, the lock quickly and easily connects and disconnects from the kickstand of the Surface Pro and Surface Go. The non-invasive locking technology is supported by anti-scratch protection to secure the device without impacting the aesthetics of a Surface Pro or impacting its hardware warranty. -
Strong lock head
Offering uncompromised security for Microsoft Surface Pro and Surface Go, the 10 mm lock head provides trusted protection that only Kensington can deliver. -
Hidden Pin technology
Offers flexible compatibility with all Kensington's 5 mm keying systems, including MicroSaver 2.0 and ClickSafe 2.0 locks, so you can leverage Kensington's custom keying solutions across your organization. Supported by Kensington's proven anti-pick Hidden Pin Technology, the Portable Keyed Cable Lock delivers protection with flexibility. -
Self-coiling steel cable
Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility with 2.3 m (7.5 ft) of cable that can shrink down to 4 inches for easy packing and better mobility.
 - Kensington Keyed Cable Lock for Surface Pro & Surface Go - security cable lock
- Product Type
 - Security cable lock
- Product Material
 - Carbon steel
- Length
 - 2.3 m
 - Anti-scratch, coiled cord, hidden pin, 5mm Keying System, non-invasive, MicroSaver 2.0 technology
- Designed For
 - Microsoft Surface Go, Go 2, Pro (Mid 2017), Pro 4, Pro 6, Pro 7
- Product Type
- Product Material
 - Carbon steel
- Length
 - 2.3 m
- Designed For
