The fastest way to turn one port into four. Slim, compact and lightweight. So when you're on the road, you get the job done.
- Kensington PocketHUB Mini USB 2.0 - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x USB
- 8.3 cm x 3.8 cm x 1.3 cm
- Black
- System Requirements
- Apple MacOS 8.6 or later, Microsoft Windows 98 or later
- Localisation
- Europe
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 4 x USB
- 4 x USB Type A , 1 x USB Type A
- Black
- Cables Included
- 1 x USB cable
- Plug and Play
- Localisation
- Europe
- OS Required
- 8.3 cm
- 3.8 cm
- 1.3 cm
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.16 |
