Kensington POCKET HUB MINI 4 PORT USB 2.0
Quicklinx: 7899WS00 Mfr#: 33399EU
The fastest way to turn one port into four. Slim, compact and lightweight. So when you're on the road, you get the job done.
Kensington PocketHUB Mini USB 2.0 - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB
8.3 cm x 3.8 cm x 1.3 cm
Apple MacOS 8.6 or later, Microsoft Windows 98 or later
Europe
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB
4 x USB Type A , 1 x USB Type A
1 x USB cable
Plug and Play
Europe
8.3 cm
3.8 cm
1.3 cm
7899 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
