Kensington TrackballWorks
idea: Your trackball, your rules.
Download Kensington TrackballWorks software to customise the functions of each of the buttons found on this Kensington trackball. The result is a more productive and truly personalized computing experience. Set your preferred functions or keyboard shortcuts for each trackball button or combination of buttons, adjust the pointer speed and acceleration and do so much more. Best of all, by allowing you to personalise your trackball experience, TrackballWorks makes your trackball work the way you do. TrackballWorks is compatible with the latest operating system versions including Windows 7, Windows Vista , Windows XP and Mac OS.
 - Kensington Orbit - trackball - USB
 - Trackball
- Connectivity Technology
 - Wired - USB
- Orientation
 - Right and left-handed
- Localisation
 - Europe
- Movement Detection Technology
 - Optical
- Buttons Qty
 - 2
 - Scroll ring, removable wrist rest
- Cables Included
 - 1 x USB cable - integrated
- OS Required
 - Apple MacOS X 10.8 or later, Microsoft Windows 7 or later, Google Chrome OS 44 or later
- Microsoft Certification
 - Compatible with Windows 7
 - 2-year warranty
 - Trackball
- Orientation
- Localisation
 - Europe
Input Device
 - Wired
- Interface
 - USB
 - Optical
- Buttons Qty
 - 2
 - 1 x USB - 4 pin USB Type A
- Included Accessories
 - Wrist rest
- Cables Included
 - FCC Part 15, Plug and Play
- OS Required
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
