Kensington One-Touch Height Adjustable Single Monitor Arm
Quicklinx: G8RRWS00 Mfr#: K55470EU
£76.26 ex VAT
£91.51 inc VAT
Improve posture, promote proper eye alignment and support neck and shoulder comfort with the Kensington SmartFit One-Touch Height Adjustable Monitor Arm. Ergonomically designed to promote wellness and increase productivity, the SmartFit One-Touch Height Adjustable Monitor Arm incorporates Kensington's patented SmartFit technology to simplify proper fit and allows users to adjust the height, depth and angle of their monitor for individualised comfort. Stable at any monitor position, users can easily switch from landscape to portrait mode. An ideal monitor arm for the modern office and a perfect complement to the SmartFit Sit/Stand Desk (K52804WW).
  • SmartFit system
    Simplifies ideal ergonomic height positioning using scientifically proven research to support proper fit.
  • One-touch adjustable arm with built-in gas spring
    Full motion articulation allows you to easily customize the position of the monitor in your workstation. Move monitor up, down, forward and backwards with 170-505mm height adjustment, 180° swivel and rotation and +/- 90° tilt adjustment.
  • Stability focused design
    Supports 13" - 32" flat or curved monitor weighing up to 9kg, ensuring your monitor is stable and steady in any position.
  • Easy to install
    Includes quick release detachable VESA plate, C-clamp and grommet.
  • Cable management system
    Keeps monitor cables organized for a tidier workspace.
Kensington SmartFit One-Touch Single Monitor Arm mounting kit - adjustable arm - for Monitor
Mounting kit (adjustable arm) - desktop, C-clamp, grommet, desk-mountable
590 mm x 115 mm x 665 mm
Tilt
-90° to 90°
Lift
17 - 50.5 cm
Rotation
180°
Swivel
180°
Adjustments
3.34 kg
Europe
Recommended Use
Monitor
Recommended Display Size
13"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9 kg
Material
Plastic, aluminium, steel
Package Content
Installation tool
590 mm
115 mm
665 mm
3.34 kg
Material
Europe
Package Content
Installation tool
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
Monitor
Placing / Mounting
Desktop, C-clamp, grommet, desk-mountable
Cable Management
Cable Management System (CMS)
13"-32"
Tilt
-90° to 90°
Lift
17 - 50.5 cm
Rotation
180°
Swivel
180°
Adjustments
Max Load Weight
9 kg
Details
Gas spring lift
Brand: Kensington
