Kensington One-Touch Height Adjustable Single Monitor Arm - Black
Quicklinx: G8T9WS00 Mfr#: K59600WW
30 In Stock
£74.72 ex VAT
£89.66 inc VAT
The SmartFit One-Touch Height Adjustable Single Monitor Arm makes it easy to find the proper monitor height (and a neutral, comfortable posture) with its patented SmartFit System and fully articulating design. Tested to meet ANSI/BIFMA standards, a heavy duty build guarantees stability in every position while its gas spring monitor mount makes adjusting your monitor's height, depth and angle effortless, from landscape to portrait mode. The product's built-in cable management system organises and conceals cables while the arm lifts your external monitor up and out of the way, decluttering and clearing valuable desk space at once. Kensington durability guarantees a more ergonomic workspace for years to come.
  • SmartFit system
    With SmartFit, finding the right height for maximum comfort is as easy as 1-2-3. Simply match your hand size to the color on the provided chart, set the height to your color and you're done.
  • One-touch adjustable arm with built-in gas spring and counterbalance tension adjustment
    Enjoy effortless adjustment of your external monitor's height, depth and angle with a fully articulating monitor arm. With 170 - 505mm height adjustment, ±90° swivel and monitor rotation, and ±90° tilt adjustment, the One-Touch gas spring monitor mount gives you total control over the placement of your external monitor, from landscape to portrait mode. Its counterbalance tension adjustment allows you to "tighten" or "loosen" the arm to accommodate a range of monitor weights with the same effortlessness and stability.
  • Heavy-duty, stability focused design
    The Kensington SmartFit One-Touch Height Adjustable Single Monitor Arm is stable in every position, supporting a 13" - 34" flat or curved monitor weighing up to 9kg.
  • Easy, non-permanent installation
    Mountable by C-clamp or grommet hole, installation is non-permanent and non-marking, making removal easy.
  • Cable management system
    Organizes and conceals cables while the arm lifts your external monitor up and out of the way, decluttering cables and clearing valuable desk space at once.
  • Kensington durability
    Trust in the dependability of a heavy-duty monitor arm and enjoy stability and effortless adjustment for years to come.
Kensington SmartFit One-Touch Height Adjustable Single Monitor Arm mounting kit - adjustable arm - for Monitor
Mounting kit (adjustable arm) - desktop, C-clamp, grommet, desk-mountable
590 mm x 115 mm x 665 mm
Tilt
-90° to 90°
Lift
17 - 50.5 cm
Rotation
180°
Swivel
180°
Adjustments
3.34 kg
Recommended Use
Monitor
Recommended Display Size
13"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9 kg
Material
Plastic, aluminium, steel
Package Content
Installation tool
590 mm
115 mm
665 mm
3.34 kg
Material
Package Content
Installation tool
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
Monitor
Placing / Mounting
Desktop, C-clamp, grommet, desk-mountable
Cable Management
Cable Management System (CMS)
13"-34"
Tilt
-90° to 90°
Lift
17 - 50.5 cm
Rotation
180°
Swivel
180°
Adjustments
Max Load Weight
9 kg
Details
Gas spring lift
Brand: Kensington
