Kensington One-Touch Height Adjustable Dual Monitor Arm
Quicklinx: G8RVWS00 Mfr#: K55471EU
20 In Stock
£88.40 ex VAT
£106.08 inc VAT
Improve posture, promote proper eye alignment and support neck and shoulder comfort with the Kensington SmartFit One-Touch Height Adjustable Dual Monitor Arm. Ergonomically designed to promote wellness and increase productivity, the SmartFit One-Touch Height Adjustable Dual Monitor Arm incorporates Kensington's patented SmartFit technology to simplify proper fit and allows users to adjust the height, depth and angle of their monitors for individualised comfort. Stable at any monitor position, users can easily switch from landscape to portrait mode, or from stacked to side-by-side configurations. An ideal monitor arm for the modern office and a perfect complement to the SmartFit Sit/Stand Desk (K52804WW).
  • Effortless adjustability
    Featuring a gas spring lift and an adjustable arm design, the Kensington SmartFit One-Touch Dual Monitor Arm allows for easy height adjustments from 17 cm to 50.5 cm, ensuring an ergonomic viewing angle for every user.
  • Comprehensive compatibility
    Designed to support two monitors ranging from 13" to 32" and up to 9 kg each, this mounting kit is compatible with both 100 x 100 mm and 75 x 75 mm flat panel mount interfaces, making it a versatile solution for a wide array of monitor setups.
  • Streamlined workspace
    With its integrated Cable Management System (CMS), the Kensington SmartFit One-Touch Dual Monitor Arm keeps cables neatly organized, promoting a clutter-free desk environment and enhancing productivity.
Kensington SmartFit One-Touch Dual Monitor Arm mounting kit - adjustable arm - for 2 monitors - silver grey
Mounting kit (adjustable arm) - C-clamp, grommet, desk-mountable
46.9 cm x 57.4 cm x 11.6 cm
Tilt
-90° to 90°
Lift
17 - 50.5 cm
Rotation
180°
Swivel
180°
Adjustments
7.75 kg
Europe
Recommended Use
2 monitors
Recommended Display Size
13"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9 kg
Material
Metal
Silver grey
Package Content
Installation tool
46.9 cm
57.4 cm
11.6 cm
7.75 kg
Material
Metal
Silver grey
Europe
Package Content
Installation tool
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
2 monitors
Placing / Mounting
Cable Management
13"-32"
Tilt
-90° to 90°
Lift
17 - 50.5 cm
Rotation
180°
Swivel
180°
Adjustments
Max Load Weight
9 kg
Details
Gas spring lift
