Kensington NanoSaver Dual Head Lock - Master Keyed
Quicklinx: G8LNWS00 Mfr#: K64449M
£57.99 ex VAT
£69.58 inc VAT
Designed to fit the Kensington Nano Security Slot , the NanoSaver Keyed Dual Head Laptop Lock secures ultra-thin laptops, tablets, and 2-in-1s, as well as a secondary device featuring the industry-standard Kensington Security Slot , with the same quality and strength that has made Kensington The Professionals' Choice for more than 25 years. Developed using strict specifications, patented technologies, and rigorous testing against tough environmental conditions, the NanoSaver Keyed Dual Head Laptop Lock provides next generation security for ultra-thin devices and desktop peripherals.
  • Tough 10mm NanoSaver Lock Head with Cleat locking technology
    Offering uncompromised security for select ultra-thin laptops built with the Kensington Nano Security Slot, the lock head is only 10mm in diameter and still meets the industry-leading testing standards for tamper-resistance, reliability and durability that only Kensington can provide.
  • 5mm keying system
    Offers flexible compatibility with all Kensington's 5mm keying systems, including MicroSaver 2.0 and ClickSafe 2.0 locks, so you can leverage Kensington's custom keying solutions across your organization. Supported by Kensington's proven anti-pick Hidden Pin Technology, the NanoSaver delivers protection with flexibility.
  • Carbon steel cable
    Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility with 1.8m (6 ft.) of cable.
  • Pivot and rotate cable
    Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
  • Register and Retrieve
    Kensington's online key registration program that allows for quick, secure and easy key replacement if it ever gets lost or stolen
  • Verified and tested
    Engineered to Kensington's rigorous specifications and third-party standards in torque/pull, foreign implements, lock lifecycle, corrosion, key strength and other environmental conditions.
Kensington NanoSaver Master Keyed Twin - security cable lock
Security cable lock
Silver
Product Material
Carbon steel
Cleat Locking Technology, hidden pin, kensington security slot, 5mm Keying System
Security cable lock
Product Material
Carbon steel
Thickness
5 mm
Silver
Limited warranty: - lifetime
Brand: Kensington
