Kensington N17 Serialised Combination Lock (25)
Quicklinx: G8M2WS00 Mfr#: K68010EU
£818.56 ex VAT
£982.27 inc VAT
The improved Slim N17 Serialised Combination Laptop Lock for Wedge-Shaped Slots 25-Pack delivers increased strength in a smaller size. It's the strongest keyless locking solution for laptops and tablets with a wedge-shaped lock slot, independently verified and tested for industry-leading standards in torque/pull, foreign implements, lock lifecycle, corrosion and other environmental conditions. The Slim N17 Serialised Combination Laptop Lock for Wedge-Shaped Slots 25-Pack features a stronger cable with greater pull strength, an updated slider for easy one-handed engagement of the lock, and a pre-programmed 4-number code so you can immediately put it to work without having to set the combination yourself. A serial number is etched onto the lock, making it easy to verify and retrieve a lost or forgotten combination.
Kensington N17 Serialized Combination Cable Lock for Dell Devices with Wedge Slots - 25 Pack - security cable lock
Security cable lock
Packaged Quantity
25 (specifications are for single item)
Product Material
Carbon steel
Combination lock, tamper-proof, cut-resistant, wedge lock slot
Europe
Packaged Quantity
Security cable lock
Product Material
Carbon steel
Europe
Brand: Kensington
Price Range Ex VAT: £750 - £1000
