The N17 Keyed Laptop Lock utilizes a unique lock engagement, creating a strong and reliable connection between the lock head and slot. The Keying System with anti-pick technology provides flexibility as part of Kensington's unparalleled robust custom keying solution for IT managers. A carbon steel cable deters cutting attempts and the pivot & rotate hinge diverts the cable away from other peripherals.
Unique lock engagement
Expanding side "hooks" grab on to the internal sides of the non-standard lock slot, creating a strong connection between the device frame and the lock to resist and deter theft attempts. -
Keying System
A central pillar of Kensington's locking solutions, the exclusive keying system is common across all of Kensington's locks. The unparalleled custom management options provide flexibility, and the anti-pick Hidden Pin technology offers complete peace of mind. Now IT directors will only have one keying system to manage across their organization. -
Carbon steel cable
Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility with long cable. -
Pivot and rotate cable
Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
- Kensington N17 Keyed Laptop Lock for Wedge Shaped Slots - security cable lock
- Product Type
- Security cable lock
- Package Content
- 2 x keys
- Product Material
- Carbon steel
- Pivot adjustment, rotating, cut-resistant, hidden pin, 5mm Keying System, Tough Lock Head lock slot
- Product Type
- Product Material
- Carbon steel
- Package Content
- 2 x keys
- Thickness
- 5 mm
Kensington N17 Laptop Lock - Master Keyed
