Kensington N17 Keyed Lock for Dell Laptops - Standard Keyed Security Cable Lock
Quicklinx: DJXRWS00 Mfr#: K64440WW
Device Type: Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Black/Silver
47 In Stock
£39.65 ex VAT
£47.58 inc VAT
Designed for laptops and devices with a Wedge lock slot, it meets Kensington's high standards for tamper-resistance, reliability and durability. Expanding side hooks grab on to the internal sides of the Wedge lock slot, creating a strong connection between the device frame and the lock to resist and deter theft attempts. A central pillar of Kensington's locking solutions, the exclusive keying system is common across all of Kensington's locks. Unparalleled custom management features provide flexibility, and anti-pick Hidden Pin technology offers complete peace of mind. Now IT directors will only have one keying system to manage across their organization. Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility. Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
  • Tough lock head
    Designed for laptops and devices with a non-standard lock slot, it meets Kensington's high standards for tamper-resistance, reliability and durability.
  • Unique lock engagement
    Expanding side hooks grab on to the internal sides of the non-standard lock slot, creating a strong connection between the device frame and the lock to resist and deter theft attempts.
  • 5mm Keying System
  • Carbon steel cable
  • Pivot and rotate cable
Kensington N17 Keyed Laptop Lock for Wedge Shaped Slots - security cable lock
Security cable lock
Package Content
2 x keys
Product Material
Carbon steel
Length
1.83 m
200 g
Pivot adjustment, rotating, cut-resistant, hidden pin, 5mm Keying System, Tough Lock Head lock slot
5-year warranty
Security cable lock
Product Material
Carbon steel
Package Content
2 x keys
Length
1.83 m
Thickness
5 mm
200 g
Security Cable Lock
Intended For
Notebook, tablet
Lock Type
Wedge
Limited warranty: - 5 years
Device Type: Laptop
Type: Security
Brand: Kensington
