From the industry leader in physical device security for 25 years, Kensington has developed the strongest locking solution to secure Dell laptops and tablets with a non-standard lock slot. The N17 Keyed Dual Head Laptop Lock allows you to secure a Dell laptop that has a Noble lock slot, along with a secondary device that features the industry-standard Kensington Security Slot . The 5mm Keying System with anti-pick technology allows you to use the same key for both lock heads and offers flexibility for IT administrators, as the keying system is compatible with all of Kensington's latest locks. A carbon steel cable deters cutting attempts.
Tough lock heads
The two lock heads are designed for laptops and other devices, while using the same key so you can quickly secure a laptop as well as a monitor, docking station or hard drive. -
Unique lock engagement
The primary lock head has expanding side "hooks" that grab on to the internal sides of the non-standard lock slot, creating a strong connection between the device frame and the lock to resist and deter theft attempts. -
T-bar locking technology
The secondary lock head uses the trusted industry standard that's compatible with the Kensington Security Slot found on many peripheral desktop accessories. The rotating bar securely attaches to the internal wall of the device for a premium level of security. -
5 mm keying system
A central pillar of Kensington's industry-leading locking solutions, the exclusive keying system is common across all of Kensington's latest locks. The unparalleled custom management options provide flexibility, and our patented anti-pick Hidden Pin Technology offer complete peace of mind. Now IT directors will only have one keying system to manage across their organization. -
Carbon steel cable
Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility with 6 feet of cable.
 - Kensington N17 Keyed Dual Head Laptop Lock for Wedge-Shaped Slots - Like Keyed - security cable lock
- Product Type
 - Security cable lock
- Package Content
 - 2 x keys
- Product Material
 - Carbon steel
 - T- bar lock, pivot adjustment, rotating, cut-resistant, hidden pin, 5mm Keying System, Tough Lock Head lock slot
- Product Type
- Product Material
 - Carbon steel
- Package Content
 - 2 x keys
- Thickness
 - 5 mm
