Kensington N17 Dual Keyed Laptop Lock
Quicklinx: G8BMWS00 Mfr#: K67995WW
From the industry leader in physical device security for 25 years, Kensington has developed the strongest locking solution to secure Dell laptops and tablets with a non-standard lock slot. The N17 Keyed Dual Head Laptop Lock allows you to secure a Dell laptop that has a Noble lock slot, along with a secondary device that features the industry-standard Kensington Security Slot . The 5mm Keying System with anti-pick technology allows you to use the same key for both lock heads and offers flexibility for IT administrators, as the keying system is compatible with all of Kensington's latest locks. A carbon steel cable deters cutting attempts.
  • Tough 10 mm NanoSaver lock head with cleat locking technology
    Offering uncompromised security for select ultra-thin laptops built with the Kensington Nano Security Slot, the lock head is only 10mm in diameter and still meets the industry-leading testing standards for tamper-resistance, reliability and durability that only Kensington can provide.
  • 5 mm keying system
    Offers flexible compatibility with all Kensington's 5 mm keying systems, including MicroSaver 2.0 and ClickSafe 2.0 locks, so you can leverage Kensington's custom keying solutions across your organization. Supported by Kensington's proven anti-pick Hidden Pin Technology, the NanoSaver delivers protection with flexibility.
  • Carbon steel cable
    Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility with 1.8m (6 ft. ) of cable.
  • Pivot and rotate cable
    Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
Kensington N17 Keyed Dual Head Laptop Lock for Wedge Shaped Slots - security cable lock
Security cable lock
Product Material
Steel, carbon
Length
1.83 m
Cut-resistant, hidden pin, wedge lock slot
Security cable lock
Product Material
Steel, carbon
Length
1.83 m
