Kensington N17 Combination Lock
Quicklinx: G8M1WS00 Mfr#: K68008EU
Device Type: Tablet, Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Black, Silver
Hurry, only 1 left in stock!
£33.25 ex VAT
£39.90 inc VAT
The Slim N17 Combination Laptop Lock for Wedge-Shaped Slots delivers increased strength in a smaller size. It's the strongest keyless locking solution for laptops and tablets with a wedge lock slot, independently verified and tested for industry-leading standards in torque/pull, foreign implements, lock lifecycle, corrosion and other environmental conditions. The Slim N17 Combination Laptop Lock for Wedge-Shaped Slots features a stronger cable with greater pull strength, an updated slider for easy one-handed engagement of the lock and a resettable 4-wheel number code that can be set to any of 10,000 possible combinations.
  • Unique lock engagement
    Expanding side "hooks" grab the internal sides of the wedge-shaped lock slot, creating a strong connection between the device frame and the lock to resist and deter theft.
  • Carbon steel cable
    Cut-resistant with plastic sheathing to protect desks, tables, and other fixed-structure attachment points.
  • One-handed attachment
    Re-engineered slider allows for quick and easy engagement into the device.
  • Resettable 4-wheel number code
    10,000 possible combinations, selectable by the user.
  • Register & Retrieve
    Allows for quick, easy, and secure lookup if the combination is ever lost or forgotten.
Kensington N17 Combination Cable Lock for Dell Devices with Wedge Slots - security cable lock
Security cable lock
Product Material
Carbon steel
Length
1.8 m
226 g
4 digit code, cut-resistant
Europe
Security cable lock
Product Material
Carbon steel
Length
1.8 m
226 g
Europe
Limited warranty: - 2 years
Device Type: Tablet
Device Type: Laptop
Type: Security
Colour: Black
Colour: Silver
Brand: Kensington
