The Slim N17 Combination Laptop Lock for Wedge-Shaped Slots delivers increased strength in a smaller size. It's the strongest keyless locking solution for laptops and tablets with a wedge lock slot, independently verified and tested for industry-leading standards in torque/pull, foreign implements, lock lifecycle, corrosion and other environmental conditions. The Slim N17 Combination Laptop Lock for Wedge-Shaped Slots features a stronger cable with greater pull strength, an updated slider for easy one-handed engagement of the lock and a resettable 4-wheel number code that can be set to any of 10,000 possible combinations.
Unique lock engagement
Expanding side "hooks" grab the internal sides of the wedge-shaped lock slot, creating a strong connection between the device frame and the lock to resist and deter theft. -
Carbon steel cable
Cut-resistant with plastic sheathing to protect desks, tables, and other fixed-structure attachment points. -
One-handed attachment
Re-engineered slider allows for quick and easy engagement into the device. -
Resettable 4-wheel number code
10,000 possible combinations, selectable by the user. -
Register & Retrieve
Allows for quick, easy, and secure lookup if the combination is ever lost or forgotten.
- Kensington N17 Combination Cable Lock for Dell Devices with Wedge Slots - security cable lock
- Product Type
- Security cable lock
- Product Material
- Carbon steel
- Length
- 1.8 m
- 226 g
- 4 digit code, cut-resistant
- Localisation
- Europe
- 2-year warranty
- Product Type
- Product Material
- Carbon steel
- Length
- 1.8 m
- 226 g
- Localisation
- Europe
- Limited warranty: - 2 years
Kensington N17 Combination Lock
