Kensington Monitor Stand Plus Wide - Black
Quicklinx: G8RLWS00 Mfr#: K52797WW
£44.15 ex VAT
£52.98 inc VAT
Trust the brand with 20 years of ergonomic expertise for an extra-wide monitor stand that works perfectly in the office and for home office professionals. Kensington's patented SmartFit System helps you position your monitor at the correct height without need for a specialist, reducing neck, back and eye strain. The extra-wide stand has 3 height settings and can fit larger monitors while leaving storage space under the platform to fit a full-size keyboard and maximize your desktop surface area.
  • SmartFit system
    Allows you to find your ideal setting, with adjustable snap-in risers that provide 3 height options to match to your personal comfort color using the included hand chart.
  • Reduce eye/neck strain
    By setting your monitor at the proper height that's in line with your eyes, you can lower the chances you will suffer from aches and pain after spending long hours on the computer.
  • Larger, sturdier universal platform
    The base of the stand is large enough to fit a wide variety of standard and widescreen monitors up to 18 kg. with a screen size of up to 27 inches.
Kensington SmartFit Extra Wide Monitor stand - for Monitor
Stand
61 cm x 30 cm x 15.2 cm
1.78 kg
Recommended Use
Monitor
Recommended Display Size
Up to 27"
Max Load Weight
18 kg
Material
Wood
3-year warranty
61 cm
30 cm
15.2 cm
1.78 kg
Material
Wood
AV Furniture
Stand
Recommended Use
Monitor
Up to 27"
Max Load Weight
18 kg
Assembly Required
Limited warranty - 3 years
Brand: Kensington
