Kensington Monitor Stand Plus - Black
Quicklinx: CRKKWS00 Mfr#: K52786WW
Accessory Type: Stand
£49.52 ex VAT
£59.42 inc VAT
Trust the brand with 20 years of ergonomic expertise for a monitor stand that works perfectly in the office and for home office professionals. Kensingtons patented SmartFit System helps you position your monitor at the correct height without need for a specialist, reducing neck, back and eye strain. The extra-wide stand has 3 height settings and can fit larger monitors while leaving storage space under the platform to maximize your desktop surface area.
  • SmartFit system
    Allows you to find your ideal setting, with adjustable snap-in risers that provide 3 height options to match to your personal comfort color using the included hand chart.
  • Reduce eye / neck strain
    By setting your monitor at the proper height that's in line with your eyes, you can lower the chances you will suffer from aches and pain after spending long hours on the computer.
  • Larger, sturdier universal platform
    The base of the stand is large enough to fit a wide variety of standard and widescreen monitors.
  • Desktop optimization
    Its area underneath the stand is extra wide and can be used to store accessories or papers, allowing you to maximize your desktop space.
Kensington Monitor Stand Plus with SmartFit System - monitor stand
Monitor stand
30.5 cm x 39.4 cm
1.71 kg
Monitor stand
Max Load Weight
36 kg
30.5 cm - 39.4 cm
1.71 kg
Adjustable height, SmartFit
Brand: Kensington
