Trust the brand with 20 years of ergonomic expertise for a monitor stand that works perfectly in the office and for home office professionals. Kensingtons patented SmartFit System helps you position your monitor at the correct height without need for a specialist, reducing neck, back and eye strain. The extra-wide stand has 3 height settings and can fit larger monitors while leaving storage space under the platform to maximize your desktop surface area.
SmartFit system
Allows you to find your ideal setting, with adjustable snap-in risers that provide 3 height options to match to your personal comfort color using the included hand chart. -
Reduce eye / neck strain
By setting your monitor at the proper height that's in line with your eyes, you can lower the chances you will suffer from aches and pain after spending long hours on the computer. -
Larger, sturdier universal platform
The base of the stand is large enough to fit a wide variety of standard and widescreen monitors. -
Desktop optimization
Its area underneath the stand is extra wide and can be used to store accessories or papers, allowing you to maximize your desktop space.
- Kensington Monitor Stand Plus with SmartFit System - monitor stand
- Product Type
- Monitor stand
- Black
- 30.5 cm x 39.4 cm
- 1.71 kg
- 2-year warranty
- Product Type
- Monitor stand
- Max Load Weight
- 36 kg
- 30.5 cm - 39.4 cm
- 1.71 kg
- Black
- Adjustable height, SmartFit
- Limited warranty - 2 years
