Trust the brand with 20 years of ergonomic expertise for a monitor stand that works perfectly in the office and for home office professionals. Kensingtons patented SmartFit System helps you position your monitor at the correct height without need for a specialist, reducing neck, back and eye strain. The stand has 3 height settings and leaves storage space under the platform to maximize your desktop surface area.
SmartFit system
Allows you to find your ideal setting, with adjustable snap-in risers that provide 3 height options to match to your personal comfort color using the included hand chart. -
Reduce eye / neck strain
By setting your monitor at the proper height that's in line with your eyes, you can lower the chances you will suffer from aches and pain after spending long hours on the computer. -
Desktop optimization
The area underneath the stand is open and can be utilized for accessories storage, allowing you to maximize your desktop space. -
Sturdy universal platform
The base of the stand is large enough to fit a wide variety of standard and widescreen monitors.
- Kensington SmartFit stand - for Monitor - black
- Product Type
- Stand
- Adjustments
- Recommended Use
- Monitor
- Recommended Display Size
- Up to 21"
- Black
- 3-year warranty
- Black
AV Furniture
- Stand
- Recommended Use
- Monitor
- Up to 21"
- Adjustments
- Limited warranty - 3 years
