Kensington Monitor Stand - Black
Quicklinx: CRKJWS00 Mfr#: K52785WW
Accessory Type: Stand
£28.69 ex VAT
£34.42 inc VAT
Trust the brand with 20 years of ergonomic expertise for a monitor stand that works perfectly in the office and for home office professionals. Kensingtons patented SmartFit System helps you position your monitor at the correct height without need for a specialist, reducing neck, back and eye strain. The stand has 3 height settings and leaves storage space under the platform to maximize your desktop surface area.
  • SmartFit system
    Allows you to find your ideal setting, with adjustable snap-in risers that provide 3 height options to match to your personal comfort color using the included hand chart.
  • Reduce eye / neck strain
    By setting your monitor at the proper height that's in line with your eyes, you can lower the chances you will suffer from aches and pain after spending long hours on the computer.
  • Desktop optimization
    The area underneath the stand is open and can be utilized for accessories storage, allowing you to maximize your desktop space.
  • Sturdy universal platform
    The base of the stand is large enough to fit a wide variety of standard and widescreen monitors.
Kensington SmartFit stand - for Monitor - black
Stand
Adjustments
Recommended Use
Monitor
Recommended Display Size
Up to 21"
3-year warranty
AV Furniture
Stand
Recommended Use
Monitor
Up to 21"
Adjustments
Limited warranty - 3 years
Brand: Kensington
