Kensington MiniSaver Lock Keyed Different
Quicklinx: CRM3WS00 Mfr#: K67890WW
Device Type: Ultrabook, Tablet
Type: Security
Device Screen Size: [N/A]
Colour: Black/Silver
£41.31 ex VAT
£49.57 inc VAT
The perfect security solution for modern ultra-thin devices like Ultrabooks and tablets that otherwise would be left vulnerable to theft. The MiniSaver features Cleat Locking Technology, which can be inserted into any device that includes either the Kensington Security Slot or the Kensington Mini Security Slot.
  • Cleat locking technology
    Retracting "claws" grab on to the internal sides of the security slot, creating a strong connection between the device's shell and the lock, ensuring your device will still be there when you get back.
  • Off-body lock
    A groundbreaking design, by moving the main lock housing away from the device, it creates greater flexibility so it won't interfere with surrounding ports and jacks needed to support your accessories.
  • One-handed operation
    With a simple push-button action with a single hand, the lock can be inserted and firmly locked into place inside the security slot.
  • Cut-resistant cable
    Made of engineered carbon steel and sheathed in protective plastic, it offers the same level of cut-resistance and theft-resistance of much thicker cables while providing easier mobility.
  • Pivot and rotate cable
    Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
Kensington MiniSaver Mobile Lock - notebook locking cable
Notebook locking cable
Product Material
Carbon steel
Length
1.8 m
270 g
Pivot adjustment, rotating, Cleat Locking Technology, cut-resistant
Product Material
Carbon steel
Length
1.8 m
270 g
Limited warranty: - 2 years
Device Type: Tablet
Type: Security
Brand: Kensington
