Kensington MicroSaver 2.0 Twin Keyed Lock - Master Keyed
Quicklinx: G8LHWS00 Mfr#: K65099M
£52.18 ex VAT
£62.61 inc VAT
Kensington, The Professionals' Choice for device security for nearly 25 years, has produced the latest standard in device security – the MicroSaver 2.0 Portable Keyed Laptop Lock. Engineered to be Kensington's smallest lock for laptops and other devices with no compromise, the MicroSaver 2.0 represents the next generation of laptop security with a self-coiling cable that makes it ideal for highly mobile professionals. The MicroSaver 2.0 was developed using strict specifications, patented technologies, and rigorous testing against tough environmental conditions, and can stand the test of time in a smaller, compact size.
  • Strong twin lock heads
    The two lock heads are designed for thin laptops and devices while using the same key so you can quickly secure a laptop as well as a monitor, hard drive, printer or docking station.
  • Hidden Pin technology
    The anti-pick technology ensures the lock cannot be tampered with.
  • T-Bar locking technology
    The rotating bar securely attaches to the internal wall of the device for a premium level of security.
  • Carbon steel cable
    Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility.
  • Pivot and rotate cable
    Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
Kensington MicroSaver 2.0 Keyed Twin Laptop Lock - security cable
Security cable
Package Content
Cable lock
Product Material
Carbon steel
T- bar lock, pivot adjustment, rotatable, hidden pin, Kensington security slot
Security cable
Product Material
Carbon steel
Package Content
Cable lock
Brand: Kensington
