When combined with the Kensington Charge & Sync Cabinet, Universal Tablet this 5-pack of USB to Micro USB cables allows you to keep up to 10 Galaxy Tab, Kindle or other Android tablets charged and ready for another day in the classroom. They're designed to fit perfectly with the Cabinets built-in USB ports.
- Kensington Charge & Sync Cable - charging / data cable - 20 cm
- Cable
- Charging / data cable
- Packaged Quantity
- 5 (specifications are for single item)
- Cable Length
- 20 cm
- Connector
- USB - male
- Connector (Second End)
- Micro-USB Type B - male
- Sync and charge
- Packaged Quantity
- Cable Type
- Cable Length
- 20 cm
- Recommended Use
- Tablet
- Sync and charge
- Connector
- 4 pin USB Type A - male
- 5 pin Micro-USB Type B - male
