The patented MagPro Magnetic Privacy Screen Filter for Monitors 27" (16:9) can be attached and removed quickly and easily, offering best-in-class privacy protection. An ideal solution for slim bezel or edge-to-edge displays. Privacy screen filter protects monitor from scratches and damage, while providing privacy by limiting viewing angle to +/- 30°. Reduces harmful blue light by up to 22%, diminishes glare and improves clarity. Reversible for matte or glossy viewing options.
Patented design
Slim magnetic strip allows for quick and easy attachment and removal of privacy screen. -
Limited viewing angle
Narrows the field of vision to +/- 30 degrees, helping you keep the information on your screen private and reducing the chances of a visual data breach. -
Blue light reduction and low reflective coating
Filters out harmful blue light rays by up to 22%, easing eye strain and reducing the chances of interrupting sleep patterns. Coating reduces glare for improved clarity. -
Reversible viewing
One side has a matte finish to maximize glare reduction and reduce traces of fingerprints. The other side is glossy and provides a clearer view of the monitor.
- Kensington MagPro 27" (16:9) Monitor Privacy Screen with Magnetic Strip - display privacy filter - 27" - TAA Compliant
- Product Type
- Display privacy filter
- Display Screen Size Compatibility
- 27"
- TAA Compliant
- Product Type
- 27"
Display Filter
- Aspect Ratio
- 16:9
- Surface Finish
- Glossy/matte
- Magnetic stripe, frameless, +/- 30° visible angle, blue light reduction, reversible, fingerprint-proof, low-reflective
- TAA Compliant
