Kensington MagPro Magnetic Privacy 23.8" Monitors
Quicklinx: G8VRWS00 Mfr#: K58356WW
13 In Stock
£105.27 ex VAT
£126.32 inc VAT
The patented MagPro Magnetic Privacy Screen Filter for Monitors 23.8" (16:9) can be attached and removed quickly and easily, offering best-in-class privacy protection. An ideal solution for slim bezel or edge-to-edge displays. Privacy screen filter protects monitor from scratches and damage, while providing privacy by limiting viewing angle to +/- 30°. Reduces harmful blue light by up to 22%, diminishes glare and improves clarity. Reversible for matte or glossy viewing options.
  • Patented design
    Slim magnetic strip allows for quick and easy attachment and removal of privacy screen.
  • Limited viewing angle
    Narrows the field of vision to +/- 30 degrees, helping you keep the information on your screen private and reducing the chances of a visual data breach.
  • Blue light reduction and low reflective coating
    Filters out harmful blue light rays by up to 22%, easing eye strain and reducing the chances of interrupting sleep patterns. Coating reduces glare for improved clarity.
  • Reversible viewing
    One side has a matte finish to maximize glare reduction and reduce traces of fingerprints. The other side is glossy and provides a clearer view of the monitor.
Kensington MagPro 23.8" (16:9) Monitor Privacy Screen with Magnetic Strip - display privacy filter - 23.8" - TAA Compliant
Display privacy filter
Display Screen Size Compatibility
23.8"
TAA Compliant
23.8"
Display Filter
Aspect Ratio
16:9
Surface Finish
Glossy/matte
Magnetic stripe, frameless, +/- 30° visible angle, blue light reduction, reversible, fingerprint-proof, low-reflective
TAA Compliant
Brand: Kensington
