The patented MagPro Magnetic Privacy Screen Filter for Monitors 21.5" (16:9) can be attached and removed quickly and easily, offering best-in-class privacy protection. An ideal solution for slim bezel or edge-to-edge displays. Privacy screen filter protects monitor from scratches and damage, while providing privacy by limiting viewing angle to +/- 30°. Reduces harmful blue light by up to 22%, diminishes glare and improves clarity. Reversible for matte or glossy viewing options.
                Patented designSlim magnetic strip allows for quick and easy attachment and removal of privacy screen.
                Limited viewing angleNarrows the field of vision to +/- 30 degrees, helping you keep the information on your screen private and reducing the chances of a visual data breach.
                Blue light reduction and low reflective coatingFilters out harmful blue light rays by up to 22%, easing eye strain and reducing the chances of interrupting sleep patterns. Coating reduces glare for improved clarity.
                Reversible viewingOne side has a matte finish to maximize glare reduction and reduce traces of fingerprints. The other side is glossy and provides a clearer view of the monitor.
- Kensington MagPro 21.5" (16:9) Monitor Privacy Screen with Magnetic Strip - display privacy filter - 21.5" - TAA Compliant
- Product Type
- Display privacy filter
- Display Screen Size Compatibility
- 21.5"
- TAA Compliant
- Product Type
- 21.5"
Display Filter
- Aspect Ratio
- 16:9
- Surface Finish
- Glossy/matte
- Magnetic stripe, frameless, +/- 30° visible angle, blue light reduction, reversible, fingerprint-proof, low-reflective
- TAA Compliant
