Kensington MagPro Magnetic Privacy 14" Laptop
Quicklinx: G86VWS00 Mfr#: K58352WW
Device Type: Laptop
Type: Privacy Screen
Device Screen Size: 14
Colour: Transparent
29 In Stock
£54.87 ex VAT
£65.84 inc VAT
The patented MagPro Magnetic Privacy Screen Filter for Laptops 14" (16:9) offers best-in-class privacy protection. It can be attached and removed quickly and easily, while allowing your laptop to close and enter sleep mode without removing. An ideal solution for slim bezel or edge-to-edge displays. Privacy screen filter protects monitor from scratches and damage, while providing privacy by limiting viewing angle to +/- 30°. Reduces harmful blue light by up to 22%, diminishes glare and improves clarity. Reversible for matte or glossy viewing options. Includes cleaning cloth and protective case to help prevent scratches when not in use.
  • Blue light reduction
    Filters out the harmful rays, easing eye strain and reducing the chances of blue light interrupting your natural sleep patterns.
  • Anti-reflective coating
    Reduces glare from any outside light sources that can interfere with your viewing clarity.
  • Reversible viewing
    Either side of the privacy screen can be used to different effect. One side has a matte finish to maximize glare reduction, is smooth to the touch and reduces traces of fingerprints. The other side is glossy and provides a clearer view of the monitor screen.
Kensington MagPro 14" (16:9) Laptop Privacy Screen with Magnetic Strip - notebook privacy filter
Notebook privacy filter
Installation Type
Removable - magnetic
Package Content
Cleaning cloth, protective case
Product Material
PET
31.1 cm x 0.1 cm x 18.08 cm
36 g
Display Screen Size Compatibility
14"
Magnetic stripe, +/- 30° visible angle, blue light reduction, reversible, fingerprint-proof, low-reflective, anti-glare
Product Material
PET
Package Content
31.1 cm
0.1 cm
18.08 cm
36 g
38.5 cm x 0.5 cm x 26 cm / 213 g
14"
Finish
Glossy, matte
Display Filter
Installation Type
Aspect Ratio
16:9
Scratch Resistant
Frameless
Limited warranty: - 2 years
Device Type: Laptop
Colour: Transparent
Brand: Kensington
